octopi difficulties
fatlazypig
(@fatlazypig)
octopi difficulties
hi all
so I think I have done quite well, and things seem close to working,  but not quite.
I have my RPi zero w prepared.
I have the octopi image downloaded and burned onto SD card
I edited the supplicant file with my wifi network name, and PW. and have installed into the entsy board
and enabled the RPi port via the settings menu
RPi connects to wifi, I can see this on an app on my phone. and I can direct my web browser to it's IP address.
and have gone through set up
however the state in the left column is always offline.
when I try to connect,  I can follow via the terminal tab, it sends hello messages, but times out. changing state back from connecting to offline
I'm a little stumped as to what to do next
Attachment removed
Opublikowany : 30/12/2019 1:18 am
Zooraw
(@zooraw)
RE: octopi difficulties
Sadly i have the same issue:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../octoprint-no-longer-connect-to-mk3-after-updating-from-1-3-6-to-1-3-12/
If i figure it out or get an answer i will let you know, please do the same.
Thank you,
Opublikowany : 30/12/2019 3:32 am
Sorry to break it to you, but OctoPrint is not recommended on the RPi Zero W. All of the Prusa documentation on using it is old. This comes up regularly, and many people who have tried it report that performance is dismal.
Opublikowany : 30/12/2019 6:24 am
Zooraw
(@zooraw)
@bobstro
I have seen this many time, and hear what you are saying. I am only interested in copying gcode to the SD card.
Opublikowany : 30/12/2019 6:29 am
Posted by: @devin-g
I hate to disappoint again, but while OctoPrint can copy gcode to the SD card, it is doing so via the USB interface at serial speeds. Transfers are very, very slow. They run in the background, and it does work, but a 6-10MB file may take an hour. I went down this same path, thinking transfers would occur at SD speeds, but the printer and RPi are only connected via USB at 115Kbps. Unfortunately, there's no viable SD emulation solution.
Opublikowany : 30/12/2019 6:58 am
Zooraw
(@zooraw)
@bobstro
Thank you for the info. 🙂
Opublikowany : 30/12/2019 7:51 am
fatlazypig
(@fatlazypig)
so from what you can tell does it seem like I set it up correctly,  but this limitations of the hardware, and network speed are rendering it useless,
or are you saying that there is a problem,  but essentially not worth troubleshooting it as the end result is not really usable
thanks again all
Opublikowany : 30/12/2019 8:44 am
Zooraw
(@zooraw)
I am going to try this:
https://www.amazon.com/gp/product/B07SPBNNJY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I will let you know how it goes.
Opublikowany : 30/12/2019 8:50 am
Hi  Devin,
I believe you  will have problems because  it  Only support Pictures and Video formats,not support other files formats, Picture support format :JPG, RAW, CRW, MRW, ORF, RAF, X3F, NEF,KDC, PTX, PEF, CR2, TIF, MOS, K25, MEF, MPO,SRF, SR2, DNG, ARW, RW2, BAY, DCS, DRF, NRW RWL, SRW, 3FR, PNG, BMP. Video support format :AVI, MPG, MP4, MOV, MTS, ASF, 3GP.
Opublikowany : 30/12/2019 1:53 pm
towlerg
(@towlerg)
Somewhere on this forum someone posted that they had used Toshiba FlashAir successfully.
Opublikowany : 30/12/2019 2:45 pm
I used a Toshiba FlashAir W04 16GB card for nearly a year. It worked but was finicky and slow. It finally died which is when I discovered that I could assemble a RPi 3B for similar cost and run OctoPi. OctiPi on a proper RPi is very powerful, and far superior IMO. It just requires a proper RPi and will not work well for writing to an SD card mounted in the printer. Some people are very happy with the FlashAir card, so YMMV. Your wifi setup will factor into usability.
Opublikowany : 30/12/2019 3:49 pm
Zooraw
(@zooraw)
@joantabb
It looked like a fun thing to buy either way, i will let you know for sure if it works or not.
Opublikowany : 30/12/2019 7:18 pm
Zooraw
(@zooraw)
@bobstro
I also ordered a pi4 if all else fails.
This post was modified 6 years temu by Zooraw
Opublikowany : 30/12/2019 7:20 pm
rmm200
(@rmm200)
Small note:
Don't buy a Pi 4 just because it is the latest and greatest.
Buy the Pi that is most suited to the application. For most, at this point in time, it will be the Pi 3B.
Pi 4 is a power hungry little beast, with serious cooling requirements.  It is my choice (4 GB version) for a very serviceable internet browser.
Note: Any case for a Pi 3 WILL NOT fit a Pi 4. Board layout is different.
This post was modified 6 years temu by rmm200
Opublikowany : 30/12/2019 7:41 pm
Zooraw
(@zooraw)
@robert-rmm200
I got the 4gig and some cooling for it too. I totally got it because its the latest and greatest, LOL
Opublikowany : 30/12/2019 7:48 pm
rmm200
(@rmm200)
Posted by: @devin-g
@robert-rmm200
I have to admit - you will enjoy it.
For the 4, I would definitely recommend a separate power supply; preferably the official one (they screwed up the standard, so most USB C supplies won't work).
There are some really nice cases out now. This looks good:
https://www.thingiverse.com/thing:3723481
Pair it with an ultra-quiet Noctua fan...
Opublikowany : 30/12/2019 7:58 pm
1 ludzie polubili
Zooraw
(@zooraw)
@robert-rmm200
I did get the official power supply and i got this case: https://www.adafruit.com/product/4341
Opublikowany : 30/12/2019 8:07 pm
rmm200
(@rmm200)
Posted by: @devin-g
@robert-rmm200
Adafruit has been busy! Let us know how it works out for you!
Opublikowany : 30/12/2019 8:26 pm
1 ludzie polubili
AXG68K
(@axg68k)
The Pi4 runs fine - the only drawback is less cases to choose from on thingyverse. Go for it...
Dump that Zero it really sucks.
Opublikowany : 01/01/2020 11:56 pm
