Moons stepper issue
atari2001
(@atari2001)
Moons stepper issue
Hello, im having problems with my moons steppers. i changed in the firmware the microsteps to 16 and the esteps from 100 to 200 for Y and X.
I tried different values for #define TMC2130_CURRENTS_H, too. But nothing work.
Firmware: 3.9.3
Prusa i3 MK3s
Any idea?
Attachment removed
Questa discussione è stata modificata 5 years fa da atari2001
Postato : 12/04/2021 5:22 pm
Dan Rogers
(@dan-rogers)
RE: Moons stepper issue
Which motors did you install?
Postato : 12/04/2021 5:29 pm
atari2001
(@atari2001)
MS17HA2P4100
This one: https://www.moonsindustries.com/p/nema-17-high-precision-hybrid-stepper-motors/ms17ha2p4100-000004611110015917
Postato : 12/04/2021 5:31 pm
Dan Rogers
(@dan-rogers)
Yeah.  Same ones I have.  Drop in replacements - no settings changes required.  Recommend restoring to original motor specs/settings.
Postato : 12/04/2021 6:06 pm
atari2001
(@atari2001)
Okay so again to 32 microsteps? The bondtech upgrade firmware changed to already down to 16.
Postato : 12/04/2021 6:15 pm
Dan Rogers
(@dan-rogers)
Your post reference X and Y - not E.  If you have the finer resolution motor on E, I wouldn't change that.  Only change X and Y back to stock. This was the easiest motor upgrade because I didn't need to mess with settings, or redoing them some day if I need to factory reset.
Postato : 12/04/2021 6:18 pm
atari2001
(@atari2001)
Okay, thank you I will try this out.
Postato : 12/04/2021 6:21 pm
atari2001
(@atari2001)
When I change it back to stock it looks like this:
Questo post è stato modificato 5 years fa da atari2001
Postato : 12/04/2021 6:35 pm
Dan Rogers
(@dan-rogers)
Out of my league.  I went for those motors because they required no firmware changes on a stock printer to adopt for X Y or E.  So mine are working wonderfully - nice and quiet, all of my old tuned GCODES are printing better.
You might want to seek out @Bobstro
Postato : 12/04/2021 6:37 pm
atari2001
(@atari2001)
Okay I will wait for some other ideas.
Thank you anyway 🙂
Postato : 12/04/2021 6:51 pm
Dan Rogers
(@dan-rogers)
Here's a thought.  Factory reset - should revert to whatever the original settings are.
I don't know the math - is a microstep the # of steps in a degree?   Anyway, factory reset might help you get your X/Y settings back, but then you will need to redo your E if you have changed that out to a different ratio.
Postato : 13/04/2021 1:18 pm
atari2001
(@atari2001)
I found the solution.
i talked to this a few weeks ago to a forum member and he told me that 8 microstepps won’t work on this. I tried 8 microstepps and it worked perfect. 🙂
Postato : 13/04/2021 3:00 pm
