Hemera Upgrade 3.0
address change
(@address-change)
Hemera Upgrade 3.0
Hi!
In case Herera extruders and flex printing is still a thing:
I revised my Hemera upgrade again and did an update on it!
>> here <<
The old version required to mod the Z-axis to get the full printing volume. This version only requires you to replace the X-carriage instead.
The extruder orentation is inspired by DarrinBrunner 's design.
> Previous Forum Thread
I've put some basic assembly instructions on imgur:
> Instructions
Happy Printing!
Este debate ha sido modificado el hace 5 years por address change
Respondido : 29/06/2020 10:00 pm
Chromose
(@chromose)
RE: Hemera Upgrade 3.0
Thanks for continuing to work on this!
After weeks of refreshing store pages to find one in stock, I was finally able to secure a Hemera order today and should have it in 3 weeks. I plan on going with your implementation.
Respondido : 02/07/2020 9:30 pm
Sternmiere
(@sternmiere)
Hey,
thanks for the upgrade. With this upgrade I will give the hemera a try. But could you please tell me, which parts in the firmware I need to modify? I want to compile the firmware for myself.
Thanks
Do not look upon this world with fear and loathing. Bravely face whatever the gods offer.
-- Morihei Ueshiba
Respondido : 07/07/2020 9:14 pm
address change
(@address-change)
@sternmiere
Details about FW changes are now in the print description.
sorry for letting you wait.
Respondido : 04/08/2020 5:02 pm
lint_kid
(@lint_kid)
Miembro
I am using this and if you have a donate button somewhere I would use it.
I would like to add some tips for people that might attempt this mod in the future (seems anachronistic to use a v6 and OG hemera in >=2023 but who knows)
  • Use the old hotend fan that came with your MK3 for the hemera. The fan that comes with the hemera is a different voltage and connector.
  • Pinda probe cable routing is unintuitive, see pics below
  • The stepper motor cable the Hemera comes with appears to have the blue and red wires reversed compared to the prusa stepper motor cables, however I left it alone and it spun in the correct direction
  • If the hex nut that marries the two halves of the upgrade parts keeps falling out of its hole, try a tiny bit of masking tape to take up the extra space, or use an extra long M3 screw to pull it into position so that the m3x18 can engage it.
  • I used these cables for the thermistor and and heater cartridge (if the heater cartridge has a connector, like this one )
Printed in MJF nylon from JLCPCB
This design is elegant and simple. I chose this design over the alternatives because it does not over-complicate things and gets the job done. There was serious attention to detail in the modeling as well. I think overall this is a exceptionally good design. I think this is the only design I have ever downloaded from thingiverse that *just works*.
If I had to provide some constructive criticism, I would say the worst part of this design is the nut that holds the two haves of the extruder together is hexagonal, and the hole was too oversized (for my print).
This meant that the hex nut kept moving out of position, which was infuriating while trying to hold everything else in place during the two-sides-mating-ballet. Much more critically, using a hex nut instead of a quad nut (4 sided square nut) means that the nut is much easier to overtorque, spinning and deforming the plastic hole that holds it ( this was easy to do in MJF nylon, so I can assume it would be worse in FDM PETG).
The second flaw I find with this design is the suggested cable routing path (between the two parts which slide together) is inviting cable pinching. When you slide the two halves together, it is very easy for some of the loose wires to get ground between the two haves, and you can't see whats going on or check if the wires are intact.
But again, this is a fantastic print overall.
Respondido : 24/09/2023 4:47 pm
gutkinma
(@gutkinma)
Miembro
Hey there @lint_kid!
I am also the one who is trying to anachronistically use Hemera in 2023 on my MK3s+ with MMU2S.
I can't say I am winning. At the moment I am scounting internet to  find solutions to the following problems I am facing:
1) In all firwares after 3.11 people (including myself) are getting THERMAL RUNAWAY error. This is not Hemera-issue, but a REVO-issue. Still I have not found a solutions that works for me, but I have not replaced the cables yet - maybe the issue is there.
2) with the custom x-cartridge (I am using the same one you are), I am now failing:
a) x-belt calibaration (becuase of x travel lenght I assume)
b) XYZ calibration, when the  printer is looking for 4 calibration point. Due to relocation of PINDA probe - the printer is looking for 2 of 4 points outside of the metal sheet. I have been compiling my own firmwares from scource code, with changed locations of the PINDA probe, and it did not seem to trickle down to the parameters useed for XYZ calibration, and in my inverstigation of the source code, I think locations of the 4 calibration points are hard coded, not parametrized, but in a strange way. If you have any comments here - I would appreciate it!
c) lastly, despite changing all the settings as per instructions of the Hemera cartrigde holder model, I am ocasionally getting into issues of gears gripping the filament and releasing it correctly... to me it seems like a setting problem, of adjusting how much extra distace the filament travels afterthe sensor sees loading/unloading of the filament - I just have not gotten to it yet.
Anyhow, my joys of running the printer, testing new materials, CAD modelling, etc, have turned into a never-ending routine of managing Hemera, Firmware, troubleshoting and looking for solutions. When I feel better about it (now), I find strenght to research more on the internet and seek help of others.
I am also curious - if using Hemera in >=2023 is anachronistic, what would you do instead? I am considering BambuLab alltogether 🙂
Appreciate all help in advance! I guess my post full of compaints is here mostly to confirm there are still people trying to use Hemera in 2024.
Respondido : 22/09/2024 1:03 pm
1 les gusta
MaximumMaxx
(@maximummaxx)
Miembro
This is thoroughly late, but maybe it'll be helpful if someone comes across this.
I had a revo hemera mk3s that I recently upgraded to a mk3.5s. I'm having a few issues and I've messaged support to potentially get them worked out.
The extruder itself wires in fine. I pulled back a bit of the sheathing on the extruder stepper and that allowed me to wire it really nicely. I am using the 2 pin fan that comes with the hemera so a fan check is failing. Otherwise, it's just bed leveling related things.
1. The bed probe is offset wrong, so the printer attempts to probe nearly off the sheet
2. The mesh seems to be offset causing the micro z adjustments to be at the wrong place, destroying the point of mesh leveling.
The buddy firmware is reasonably different from the mk3s firmware, so it's not as simple as just going in and changing the constants. Everything seems like it should be configurable but I don't know what values should exactly, and I don't really want to break something.
Respondido : 24/03/2025 6:30 pm
MaximumMaxx
(@maximummaxx)
Miembro
I ended up making a separate guide for the mk3.5 here
Respondido : 31/03/2025 6:27 am
