Heatbed cable with Ikea Lack Enclosure.
Yakov
(@yakov)
Hello.
I finished all parts enclosure with Lack tables V2  , but I can't solve the issue with heatbed cable.
The cover with 60 deg. makes other problem : when heatbed is on the side of LCD control panel   AND the hotend is on left-bottom side their cables collide strongly.
I also checked the option to remove the LCD panel and pushed the printer forward as far as possible, but also 1 cm is not enough to fit.
Thank you in advance.
Somebody have any idea how to correctly solve this problem ?
Postato : 15/03/2021 11:08 pm
RE: Heatbed cable with Ikea Lack Enclosure.
Picture to illustrate your point? I have several Mk3Ss in LACK v2 enclosures, using an angled cover, without any issues whatsoever, so I assume there’s something not correctly assembled or the cable routing is off.
Postato : 16/03/2021 12:41 pm
Yakov
(@yakov)
Posted by: @fuchsr
I already have returned the stock cover.
Can you please take a photo of your printer with cover 60 deg., when the heatbed is pushed forward as far as possible (towards the LCD panel) and the hotend is at the bottom left.
Postato : 16/03/2021 12:59 pm
@yakov
Wish I could do that but I'm out of town for a few more weeks, with no access to my printers. To see how the heatbed cover looks like for me, you can take a look at the make I posted: https://www.thingiverse.com/make:850251. I remember I first tried a different cover model but I can't recall what it was, which didn't quite work as well for me.
I never noticed any issues pushing the bed forward and the hotend in the left position, so I don't have a picture I could share at this point.
Maybe someone else on this forum can help.
Postato : 16/03/2021 6:11 pm
Livius
(@livius)
@yakov
Don't know if you solved your cable problem but see if this will help.
Regards/Livius
Postato : 28/04/2021 7:13 am
Utenti
@livius
Thanks for sharing that.  I am using a different one, but this is better.
Postato : 28/04/2021 11:37 am
1 persone hanno apprezzato
