Heatbed cable with Ikea Lack Enclosure.
Hello.
I finished all parts enclosure with Lack tables V2 , but I can't solve the issue with heatbed cable.
The cover with 60 deg. makes other problem : when heatbed is on the side of LCD control panel AND the hotend is on left-bottom side their cables collide strongly.
I also checked the option to remove the LCD panel and pushed the printer forward as far as possible, but also 1 cm is not enough to fit.
Thank you in advance.
Somebody have any idea how to correctly solve this problem ?
RE: Heatbed cable with Ikea Lack Enclosure.
Picture to illustrate your point? I have several Mk3Ss in LACK v2 enclosures, using an angled cover, without any issues whatsoever, so I assume there’s something not correctly assembled or the cable routing is off.
I already have returned the stock cover.
Can you please take a photo of your printer with cover 60 deg., when the heatbed is pushed forward as far as possible (towards the LCD panel) and the hotend is at the bottom left.
@yakov
Wish I could do that but I'm out of town for a few more weeks, with no access to my printers. To see how the heatbed cover looks like for me, you can take a look at the make I posted: https://www.thingiverse.com/make:850251. I remember I first tried a different cover model but I can't recall what it was, which didn't quite work as well for me.
I never noticed any issues pushing the bed forward and the hotend in the left position, so I don't have a picture I could share at this point.
Maybe someone else on this forum can help.
@yakov
Don't know if you solved your cable problem but see if this will help.
Regards/Livius
@livius
Thanks for sharing that. I am using a different one, but this is better.
