45 cm depth Rack enclosure
azrael
(@azrael)
I noticed that I have a rackmount cabinet extra. A 9U cabinet, that has enough height and width for my MK3S, but the depth is something else. It is 45cm deep, but I have 40 CM on the MK3 available, if I remove the screen. But there is stil the cable and mount of the heated bed, which is about 3 cm plus the cable. This means, that it is extremely tight.
Does anyone remember having seen someone pulling off an enclosure with a 45cm rack. I imagine I would having to change the heatbed connector
Veröffentlicht : 18/05/2021 7:24 pm
Mitglied
RE: 45 cm depth Rack enclosure
If those are internal measurements, it will work and ti has been done.
Veröffentlicht : 18/05/2021 8:03 pm
azrael
(@azrael)
@cwbullet
got a link for me on it? I've seen only builds of racks with a 60cm depth
Veröffentlicht : 18/05/2021 8:59 pm
Posted by: @azrael
There are a few alternate designs for the heat bed cable problem, here's one solution: there is nothing magic about the angle the wires are dressed.
https://www.prusaprinters.org/prints/5387-yet-another-90-deg-prusa-mk3-heatbed-cable-cover
Diese r Beitrag wurde geändert Vor 5 years von --
Veröffentlicht : 19/05/2021 12:38 am
Mitglied
@tim-2
Wow.  That is tortuous cable flow.  Looks like you have to bend them.
Veröffentlicht : 19/05/2021 1:01 am
Mitglied
This is the one I found with google: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-improvements-archive/enclosed-in-server-cabinet-for-60/
Veröffentlicht : 19/05/2021 1:40 am
