0.5 hardened nozzle
Good morning going to change my nozzle to a 0.5 hardened as was to use some lumberfill and metal fill does anyone know if when I do this did I just need to go into Prusa slicer and change the nozzle size then use the preset settings or is there other settings that need changing
RE: 0.5 hardened nozzle
I've got a set of sample profiles here that includes a 0.5mm printer profile, and notes on modifying and creating your own custom profiles here.
First try to adapt the 0.4 template to the 0.5 nozzle, change layerheigh in the slicer and save it to as an own profile. With the steel nozzle, I would increase the nozzle temperature (10 to 20 degrees C.). After the first print do the fine tuning.
