0.5 hardened nozzle
dan.butler84
(@dan-butler84)
0.5 hardened nozzle
Good morning going to change my nozzle to a 0.5 hardened as was to use some lumberfill and metal fill does anyone know if when I do this did I just need to go into Prusa slicer and change the nozzle size then use the preset settings or is there other settings that need changing
Veröffentlicht : 11/04/2020 9:52 am
RE: 0.5 hardened nozzle
I've got a set of sample profiles here that includes a 0.5mm printer profile, and notes on modifying and creating your own custom profiles here.
Veröffentlicht : 11/04/2020 1:12 pm
Posted by: @dan-butler84
First try to adapt the 0.4 template to the 0.5 nozzle, change layerheigh in the slicer and save it to as an own profile. With the steel nozzle, I would increase the nozzle temperature (10 to 20 degrees C.). After the first print do the fine tuning.
Veröffentlicht : 11/04/2020 2:58 pm
