Slic3r rotate objects by 90 degrees short cut?
Is there any way to rotate an object on the print bed by 90 degree increments without typing it in.
Maybe something like shift-R or shift-L to rotate on the x by plus or minus 90 degrees.
Also, something like ctl-R or ctl-L to rotate the select object on the y by plus or minus 90 degrees.
Even better would be icons on the main platter interface like there is to rotate the object by 45 degrees clockwise.
I am usually printing several parts and this takes up the most time of the workflow.
Veröffentlicht : 07/04/2017 5:46 am
