Slic3r rotate objects by 90 degrees short cut?
david.b14
(@david-b14)
Is there any way to rotate an object on the print bed by 90 degree increments without typing it in.
Maybe something like shift-R or shift-L to rotate on the x by plus or minus 90 degrees.
Also, something like ctl-R or ctl-L to rotate the select object on the y by plus or minus 90 degrees.
Even better would be icons on the main platter interface like there is to rotate the object by 45 degrees clockwise.
I am usually printing several parts and this takes up the most time of the workflow.
Napsal : 07/04/2017 5:46 am
