Print in the air???
andrea.b3
(@andrea-b3)
Print in the air???
Hello,
i'm trying to solve a slicing software problem.
Please can anybody help me to understand what i should do for avoid to the printer to print the top layer where is no "infill support"??
What is the solution??
Why Simplify3D don't make a flat top layer under the words instead Slic3r??
I don't want to increase the infill %.. Now it's 10%
Thanks a lot for the help 😀
Opublikowany : 26/07/2017 2:53 pm
StephanK
(@stephank)
Re: Print in the air???
Here's what i would do: add a 2nd process a few layers below where it is airpinting now and increase infill for that small section only - or even do 2-3 solid layers (enough to not run into pillowing). Btw. free upgrade to Simplify3D v4.0 makes setting up processes waaay easier...
Opublikowany : 27/07/2017 5:13 pm
AJS
 AJS
(@ajs)
Have you tried printing it? Slic3r has pretty good bridging detection, and it might just be bridging over that section.
I have had problems with supports, but never infill using Slic3r.
Opublikowany : 28/07/2017 5:08 am
