Octoprint "Object exceeds print volume in depth"
lorn.m
(@lorn-m)
Hi everybody
Just started to use my new Prusa printer with Octoprint. I am also using the included Slice3r slicer with the printer, so assume the printer profile in the slicer is correct.
Previously used Octoprint with with my Wanhoa i3 and Cura slicer.
I have created a new profile in Octoprint.
I get the following message:
"Object in EyeGlassV3_Prussa.gcode exceeds the print volume of the currently selected printer profile, be careful when printing this.
More
Object exceeds print volume in depth.
Object's bounding box: (0.00, -3.00, 0.00) × (189.93, 133.34, 65.00)
Print volume: (0.00, 0.00, 0.00) × (250.00, 210.00, 200.00)
You can disable this check via Settings > Features > "Enable model size detection [...]""
Its the -3.00 that I assume is the issue but not sure what that actually means or where I can correct it. Any ideas?
My profile settings are these, as per a previous post by "ayourk" in june 05, 2016
X:250mm
Y:210mm
Z:200mm
AxisX:6000
AxisY:6000
AxisZ:200
AxisE:300
Opublikowany : 01/09/2017 4:09 pm
AJS
 AJS
(@ajs)
Re: Octoprint "Object exceeds print volume in depth"
Since you are using the standard Prusa Slic3r, it prints a small line at Y=-3.0mm.
This line is useful, so I would not change that, I would either ignore this warning - or set the print volume to include the y=-3.0 in octoprint.
You can see the gcode for the initial test line in "start gcode" section of the printer profile in slic3r.
Opublikowany : 01/09/2017 4:34 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Octoprint Settings/Printer Profiles/Edit/Print Bed and Build Volume/Y Coordinates/Min - set to -5
Peter
Opublikowany : 01/09/2017 4:43 pm
GertL
(@gertl)
My settings looks like this, seems to work.
Gert
Opublikowany : 01/09/2017 4:49 pm
lorn.m
(@lorn-m)
Hi to you all
Thanks for such quick and clear replies! All makes sense now and I will adjust the settings as mentioned
Have a great weekend
Opublikowany : 01/09/2017 5:57 pm
