Color Print App - Problem with Retraction Lift Z
When using Color Print App in conjunction with retraction / lift Z entries in slic3r-gcode there might be problems with multiple switches to the same trigger Z hight of an object.
Publié : 27/06/2016 3:55 pm
Re: Color Print App - Problem with Retraction Lift Z
Thomas
I find it easier to simply edit the GCode and add the M600 command where I want it. This is especially true when printing with Z-Lift.
Peter
Publié : 27/06/2016 5:56 pm
It's definitely not recommended to use Z-Lift/Z-Hop for a ColorPrint job. I believe this is why the Prusa build of Slic3r has a different profile for ColorPrint and ZHop.
Publié : 27/06/2016 7:53 pm
