Color Print App - Problem with Retraction Lift Z
TOTO
 TOTO
(@toto-2)
When using Color Print App in conjunction with retraction / lift Z entries in slic3r-gcode there might be problems with multiple switches to the same trigger Z hight of an object.
Opublikowany : 27/06/2016 3:55 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Color Print App - Problem with Retraction Lift Z
Thomas
I find it easier to simply edit the GCode and add the M600 command where I want it. This is especially true when printing with Z-Lift.
Peter
Opublikowany : 27/06/2016 5:56 pm
richard.l
(@richard-l)
Member Moderator
It's definitely not recommended to use Z-Lift/Z-Hop for a ColorPrint job. I believe this is why the Prusa build of Slic3r has a different profile for ColorPrint and ZHop.
Opublikowany : 27/06/2016 7:53 pm
