Re: Vertical artifacts
Thats where the perimeter starts and stops. Most slicers allow you to pick where to have them. Usually you can choose the rear of the print, or a 90 degree corner to help hide them. You can sometimes tell if its bigger at the beginning of the perimeter, or at the end. There is also a randomize option that should disperse them more to make them less noticeable because they wont be lined up together.
You can play with retraction and coast settings a bit. I find that nearly any print will have them at least a little bit.
Postato : 31/05/2017 7:34 pm
Topic starter
answered:
Ah that makes sense!
Thanks, i will try to optimize those settings.
Postato : 31/05/2017 8:21 pm
