selftest x-axis fail
framlin
(@framlin)
Hello,
I have just assembled my new mk3.
My current problem - among others - is, tha tthe selftest fails with a x-axis error.
I checked the movemement, it is free movable and the belt is 250 for the x-axis.
I have checked the pulley, it is thight and does not slip.
I tried it several times, it always fails.
Any idea, what the problem could be?
Have a nice day and thanks in advance.
Respondido : 04/03/2018 9:41 pm
Martin Wolfe
(@martin-wolfe)
Re: selftest x-axis fail
Have you checked the position of the zip ties on the extruder cable clamp? The position of those is critical as they can foul the full travel of the X axis.
Martin
Martin Wolfe
Respondido : 04/03/2018 9:47 pm
Sean Connelly
(@sean-connelly)
I'm having the same problem in the initial set up. Adjusted my zip-ties as suggested above, but no luck.
Respondido : 04/03/2018 11:39 pm
chad.p4
(@chad-p4)
I had the x-axis fail issue and need to switch the GT2-16 pulley on the x-axis as I had it backwards. Teeth need to be closest to the motor.
Respondido : 05/03/2018 3:11 am
framlin
(@framlin)
I checkt the zip-ties and the pulley, seems both to be ok
Respondido : 05/03/2018 3:54 pm
george.f3
(@george-f3)
I had a recent x-axis fail because the cable from the PINDA was hitting the x-axis idler.
Respondido : 06/03/2018 8:46 pm
