[Cerrado] Print bed vibration
richard.l
(@richard-l)
Miembro Moderator
Print bed vibration
This is something I have been dealing with since day one and can't seem to find a solution on my own.
A change in the Y-Axis while printing causes a vibration into the print bed. It is noisy and irritating, especially if there are many axis changes in rapid succession. It's not the zip ties on the carriage but the actual screws that go down into the carriage.
The anti vibration feet are installed but don't seem to help this problem.
Does anyone have ideas?
Respondido : 17/01/2016 4:39 pm
Josef Průša
(@josef-prusa)
Miembro Admin
Re: Print bed vibration
Do you run the latest FW?
Founder and owner / Majitel a zakladatel
Respondido : 17/01/2016 4:44 pm
richard.l
(@richard-l)
Miembro Moderator
Yes, I am running the latest firmware.
It's like the holes are just a hair too big or the screws too small.
Respondido : 17/01/2016 4:55 pm
Josef Průša
(@josef-prusa)
Miembro Admin
Do you use the clips to hold the glass? Usually they are the reason for rattling sounds.
Respondido : 17/01/2016 5:05 pm
richard.l
(@richard-l)
Miembro Moderator
Had it with the glass /clips setup as well as with the geckotek bed I am now using. If I just lightly touch the bed while it's printing the vibration and sound goes away.
I don't know if the vibrations are having an effect on the prints since I don't have anything to compare against.
Respondido : 17/01/2016 5:08 pm
Josef Průša
(@josef-prusa)
Miembro Admin
You can always share picture of the prints and we can tell if it has effect.
For a quick test I would use a bit of kitchen cling film on the tip of the screw before putting the bed in the y-carriage.
Respondido : 17/01/2016 5:16 pm
richard.l
(@richard-l)
Miembro Moderator
Genius idea. I'll try the cling film and see what happens.
Respondido : 17/01/2016 5:26 pm
ufanders
(@ufanders)
RE: Print bed vibration
Posted by: @richard-l
I have the same issue, did the cling film solution work for you?
Respondido : 11/07/2020 11:26 pm
ufanders
(@ufanders)
Hmmm, after some more thorough investigation it seems like there is some slop within the single linear bearing under the Y axis. I expect the only way to solve this is to modify the rod mounts on this side - offset the rod mount clip by 0.1mm - 0.2mm toward the outside. This might pull the slop out.
Where can I find the model for this part? And what material was is printed in?
Thanks!
Respondido : 13/07/2020 1:57 am
Holck
(@holck)
@anders-k-nelson
Its an old thread...dont know which model you have but all the i3 parts are here available here: Prusa Website and Prusa Github
the rod clamp is called "y-rod-holder.stl"
0.2 mm layer height, infill 20% GRID and material PETG.
Respondido : 19/07/2020 8:55 pm
