Preheat error when heating bed to 100c
verscheures
(@verscheures)
Whenever i try to preheat for ABS I get a preheat error when the bed reaches about 96C
When I help the bed a bit with a hot airgun it reaches a 100C and i can print without problems.
The printer is a standard MK2S, the only modification a e3d silicon sock on the print head.
Lower bed temperatures give no problem (90C and lower).
I have checked the voltages on PSU and the bed:
PSU without any heating : 12.88 V
PSU with during preheating: 12.30 V
Bed input voltage 11.80 V
Ambient temperature around 18C
Printer MK2S kit
Firmware 3.0.10
Is this normal behaviour or do i have a problem somewhere and if so is there a solution for my problem besides using a heat gun.
Veröffentlicht : 11/05/2017 7:23 pm
marathonmike
(@marathonmike)
Re: Preheat error when heating bed to 100c
I have a two week old kit with the same issue. If I add a blanket of paper towels on the bed while heating it reached 100 degrees and then will start to print, but cools off after a few layers.
Do you need it to be in an enclosure? Would adding insulation under the bed help? I saw some people adding cork sheets or Ceramic Fiber Insulation Blanket.
Any suggestions?
(FYI - I did check the themister and it is in the foil and taped in place.)
Veröffentlicht : 12/05/2017 4:06 am
Cica
 Cica
(@cica)
There's a new firmware at https://github.com/prusa3d/Prusa-Firmware/releases that fixed this problem for me.
Veröffentlicht : 12/05/2017 2:11 pm
actibbs
(@actibbs)
Also,
Make sure you are not running the cooling fan.
Andrew
Veröffentlicht : 12/05/2017 8:51 pm
marathonmike
(@marathonmike)
Also,
Andrew
Do you mean the part cooling fan, right? Hot end needs to be cooled I assume.
Veröffentlicht : 12/05/2017 10:16 pm
mrmac
(@mrmac)
This may be late, but I have been running my mk2 for a year and recently I have noticed it taking longer to get upto the higher temp i.e. 95 to 105.
Please check the heat bed plug on your rambo as mine has melted and made a mess.
I think the movement loosens the screws securing the heat bed wire into the plug causing high resistance.
What I have done now is to use a separate misfit relay to take the load away from the mini rambo. These are only £15 uk.
I also have a migbot i3 clone which got me hooked and made me buy an original Prusa I3. I could never heat the bed hot enough to print abs until I fitted an external mosfet taking the load away from my electronics. Highly recommend this to save your own Prusa I3`s
Veröffentlicht : 13/05/2017 7:18 pm
verscheures
(@verscheures)
I checked all the cables and they where all seated om and conectors looked good.
I am wondering if this is a psu problem, since the voltage drop seems fairly significant.
I might try a preheat of a lab supply or atx psu just to see if that works
Veröffentlicht : 14/05/2017 1:47 pm
