P.I.N.D.A. probe autocalibration details
prusayo
(@prusayo)
I would like to know more about the P.I.N.D.A. probe in MK2. I know the latest video mentions the upper part being at a certain spot, but what about the actual black probe part in relation to the nozzle. Should the probe always be higher than the nozzle? Or lower than the nozzle? How much? Is there documentation on this? How can I setup this autocalibration probe accurately?
It seems that if the probe is too high there is a danger of the nozzle hitting the bed, but if it's too low the nozzle will be too high thus resulting in the nozzle being too far away resulting in prints not sticking. Also, is there a possibility that the probe, as it goes past the just printed part, could wipe past it and lift it off the plate?
I believe to make the probe lower one should turn the upper screw counter clockwise so the nut goes up and when it's pushed down, the probe goes lower. Likewise, to make the probe higher, one should turn the upper screw clockwise so the nut goes down and when it's pushed down, the probe goes higher. Is that correct?
Respondido : 28/05/2016 5:49 am
Thyn
 Thyn
(@thyn)
Re: P.I.N.D.A. probe autocalibration details
+1
I just wanted to ask the same thing: how to adjust the pinda probe. Early on, the guide says, 'we'll come to that later', but it never mentions what is the exact correct position of it.
Respondido : 28/05/2016 9:09 am
christophe.p
(@christophe-p)
Miembro Moderator
Hi guys,
Did you warch the video hands-on that Josef just published ?
It.s here (hope the link is ok):
My understanding of the calibration is that the position of the probe provide a rough level of precision (with a prcision of some half mm maybe) and the additionnal phase based on calibration prints samples refine the precision downto 1/10 th of mm, or maybe less.
I'm like Jon Snow, I know nothing.
Respondido : 28/05/2016 9:52 am
Josef Průša
(@josef-prusa)
Miembro Admin
Hi guys,
the probe needs to be higher than the nozzle. If both are at the same level, the probe could hit the part being printed. The calibration g-code prints few circles with different offsets set to the probe. When you pick one, it saves the setting into the memory.
Check out our manual here http://prusa3d.com/downloads/manual/prusa3d_manual_mk2_en.pdf There is a whole chapter on the calibration.
If you feel uncomfortable with this process, we found out easier way to calibrate the offset. We will publish it today 🙂
Founder and owner / Majitel a zakladatel
Respondido : 28/05/2016 1:12 pm
SANSÉ
(@sanse)
Hi
I have to say it did work ok went I build it, the first layer was not to bad, not perfect but ok
But it getting worst and worst
So I restart at beginning
What if I did everything like video and manual
Run all test and pass
And am not able to get a correct first layer
Even if I am adjusting the live Z at -1.000
Move my probe 2 mm higher then what is show
Re did all test and pass
And still am not able to have a nice first layer
If move my probe a bit higher , the nozzle will touch the bed or sheet of paper I should say
It like the firmware do not take care of live adjust Z value
I upgrade the firmware to the new version because had also problem with bed temperature over 93 C (now it fix)
But still not able to get a nice first layer except one time it did a very tiny layer and a other time a perfect one
Now went start a print, one in a wild, I Getting error like probe is not connected or the Sensor triggers to high, but never two time in a row and not every time
even if all test calibration pass every time without error
Live Z ajust at -1.500
So a put the bribe back to what it should be an now getting xyz calibration failed bed calibration point not found
it like the probe is not ok ... or I my comprehension is wrong
Sorry for my bad English ... I am French
Anybody out there to help please
Tanks very mush
Respondido : 17/05/2017 3:21 pm
Slider162
(@slider162)
The probe should be 0.75 to 1mm above the nozzle. Get some feeler gauges to measure. Once the XYZ calibration is finished, run the calibration V2 on the SD Card. Use the Live Z Adjust during the print to get a nice smushed first layer. It should be about -.500. So if the PINDA probe is 1mm above the nozzle, the Live Z Adjust will be closer to -0.250. If the PINDA is closer to -0.75mm above, the Live Z Adjust will be closer to -0.5mm. If your Live Z Adjust is greater than -1mm, then you need to raise the PINDA probe.
Respondido : 17/05/2017 5:38 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
@marc.c: have you read, and understood this thread?
Respondido : 17/05/2017 5:43 pm
SANSÉ
(@sanse)
Hi Tks for answer
I have some filer gage and have exactly 1mm from probe and nozzle
Also I have Honza from Prusa
Asking for test
Like commande G80 calibration and G81 result
This give some mesure from 9 spots testing
I do not get similar result from 3 try
So waiting for conclusion
Tks
Respondido : 17/05/2017 6:03 pm
SANSÉ
(@sanse)
Hi
Did not work with probe at 1.000 frime nozzle and live ajust at -1.000
This morning did a factory reset
Ajust my probe at 1.35 mm from bed , with nozzle touching bed
Run test calibration xyz
Run v2 calibration but was not able to get un nice layer with live adjust Z at -1.000
So
I move axis z to 0
Put a sheet paper on bed
And with live ajust z, try to move so the nozzle touch the paper
And got .... -2.640
So I think the probes is to sensitive
What do you think
Tks
Regards
Respondido : 18/05/2017 3:36 pm
SANSÉ
(@sanse)
Receive a new prob very fast and now is work perfecly
Tks
Respondido : 30/05/2017 5:40 pm
stevehlau
(@stevehlau)
Marc,
Where did you get your probe, did you purchase the probe from Prusa or some aftermarket one. I believe mine did the same thing as yours and now I have a Prusa i3 MK2 brick sits at the corner of my garage and collecting dust. 🙁
Respondido : 06/09/2017 12:56 am
