LCD shows blank rows
Kunal
(@kunal)
I just finished assembling the printer but the LCD shows two rows of blank squares.
Here is a photo of the LCD screen
Photo of the connectors on the LCD side
Photos of the connectors on the Rambo side
I did go through the following thread but decided to make a new post as I don't want to try flashing firmware or trying different orientations of connectors myself, without any guidance.
http://shop.prusa3d.com/forum/viewtopic.php?f=6&t=311&start=10
Any help is appreciated.
Respondido : 06/12/2015 7:58 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: LCD shows blank rows
Hi
Yes, I too had this issue; I know the firmware was loaded as I could hear a clicking when turning the control knob.
My printer is currently in use and I can't move it to check the connections, but what worked for me was to swap over cable 1 and 2 at both ends.
This does seem to be a really strange fix as the cables and connectors appear identical. I have had fun in the past assembling ribbon cables and am aware that is is possible that a bad connection can happen very easily, and can be "repaired" simply by pushing the connector firmly into the socket.
For a start, try swapping the cables over.
Peter
Respondido : 06/12/2015 10:33 am
Kunal
(@kunal)
Thanks Peter,
Swapping the cables worked partially. The LCD showed welcome screen. However, I cannot scroll. I believe, the ribbon cables are not crimped properly. I will check all connections with multimeter tomorrow and post my findings.
Kunal
Respondido : 06/12/2015 10:58 am
PJR
 PJR
(@pjr)
Hi Kunal
It may be better if you contact PR via the "Live Chat" on the shop pages. Give then the link to this topic and they may be able to get you a new set of ribbon cable sent out.
As soon as my printer finishes the current job, I will let you know how mine is wired; I have a suspicion that one of the cables is reversed.
Peter
Respondido : 06/12/2015 11:29 am
PJR
 PJR
(@pjr)
OK there is a definite lack of consistency in the manufacture of these ribbon cables, which needs to be addressed.
On my printer, one cable has the red stripe on pin 1 and the other on pin 10, but on both connectors, pin 1 goes to pin 1. On my LCD panel, pin 1 is denoted by a square solder pad for the connector - all the others are round and on the RAMBO the pin number are marked.
As suggested, contact PR and they will get you sorted.
Peter
Respondido : 06/12/2015 1:36 pm
Kunal
(@kunal)
So, I checked the cables with multimeter. Only one cable is OK. The second cable has 4 pins with no connectivity. I used a vice to clamp the connectors tight but that didn't work. I am contacting PR now.
Thanks for your help, Peter.
Kunal
Respondido : 06/12/2015 10:20 pm
PJR
 PJR
(@pjr)
Hi Kunal
OK, that's no good. Please let us know what happens.
Peter
Respondido : 06/12/2015 10:48 pm
osvold
(@osvold)
Hello,
i have had exactly the same problem. The cable for P2 is defect. The printer can be run from computer without any problems in the meantime, until you get new cable.
Respondido : 06/12/2015 10:55 pm
fl0PPsy
(@fl0ppsy)
This is the exact same issue I had. In my case I could crimp the cables together properly and then the LCD started working.
There is definitely a bad batch of ribbon cables going around at the moment.
Respondido : 07/12/2015 10:53 am
PJR
 PJR
(@pjr)
Hi
Last evening, I e-mailed Jakub to see if the quality of the cables can be improved. I have a feeling that the cables are bought in with the LCD panels (there was also an issue with these).
Hopefully this can be resolved quickly and all those suffering (as I did) can get replacements.
Peter
Respondido : 07/12/2015 11:28 am
fl0PPsy
(@fl0ppsy)
Replacement cables would be good. I've noticed that if I move one of the plugs even slightly the cable stops working. If I push it back together then its ok again. Looks like its barely making contact as long as its not moved or disturbed.
Respondido : 08/12/2015 3:43 am
Kunal
(@kunal)
So, here is an update.
I should receive a new set of cables sometime in this week.
I also successfully controlled the printer using Pronterface and printed first part (Batman symbol) using provided Gcode. It printed really nice. I didn't have to make any changes to anything. I will explore it more in this week.
Kunak
Respondido : 08/12/2015 8:15 am
PJR
 PJR
(@pjr)
Kunal
Great news, well done!
Marcus - contact Prusa support via the "Live Chat" on the shop pages and advise them of the problem.
Peter
Respondido : 08/12/2015 8:35 am
Kunal
(@kunal)
So, I received new set of cables. They are good. Everything works fine now. I was able to print through sd card.
Kunal
Respondido : 10/12/2015 7:46 am
