Crooked Extruder Nozzle
charlie.b2
(@charlie-b2)
Just wanted to check before I attach it to the rest of the printer?
Is it ok if this is crooked?
https://ibb.co/fs7DN5
It's from straight out of the box. I've tried twisting it a bit but it won't budge and I don't want to use too much force.
Postato : 28/07/2017 9:38 am
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Crooked Extruder Nozzle
Unmount the cover and simply turn the heatsink.
Postato : 28/07/2017 11:59 am
Bill
 Bill
(@bill-3)
You might even be able to twist it without loosening anything. Be sure to turn it clockwise so as not to possibly loosen the heat sink from the heat brake.
Postato : 29/07/2017 7:27 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
it looks as if you've loosened the heatbreak inside the heater block.
the heatbreak and the nozzle need "to kiss" each other firmly inside the heater block, at a high temperature !
so they need to be assembled "watertight" when the hotend is heated up to about 275°C.
you need this to get fixed before you extrude any filament through the hotend, otherwise you'll get a leakage above the heater block, or at the threads of the nozzle.
simply screwing the parts together with your hands at room temperature won't do the job.
I did this at the first assembly of my kit (last november) and ran later on into nasty leakage issues... and it was a really pita to get everything cleaned up and properly assembled at the second attempt.
have a look at this thread, where the hotend is described in detail (we use the E3D v6, not the lite version !).
and watch thomas sanladerers video about choosing a nozzle and assemble it properly inside the hotend.
Postato : 29/07/2017 8:58 pm
