Consistent line gaps on Z axis - why? (SOLVED)
I have tried every possible combination of settings in Simplify 3D. I keep getting these lines, despite different materials, temperatures, print speeds, cleaned nozzle, factory reset etc.
Does ANYONE have a clue what's causing this?
Original Prusa i3 MK2
Opublikowany : 11/11/2016 7:59 pm
Re: Consistent line gaps on Z axis - why?
What material are you printing and at which temperature? Is the extruder motor skipping steps?
Opublikowany : 11/11/2016 10:06 pm
Have you printed some of the .gcode files that came on the SD card with the printer?
If they print fine, then it's probably a software issue.
You could try Slic3r with the custom Prusa config bundle.
Opublikowany : 11/11/2016 10:14 pm
