[Chiuso] Are all 5 stepper motors the same?
Pagina 2 / 2
ozzloy
(@ozzloy)
Re: Are all 5 stepper motors the same?
Spot on minus I ordered 300mm on the leadscrews ggrrrr. Should have measured 🙄 I guess I will need to put the bracket down if I ever need to use them in the future or will that pull my Z calibration off?
If you need any tech specs let me know. These are exactly the ones from the MK2 minus the wrong size leadscrew 😳
where did you order these from? i've been looking for hours!
Postato : 15/01/2017 4:44 am
IsmaelPR1
(@ismaelpr1)
Ben
Print bottom brackets which lift the motos upwards (been there already...)
Peter
Hi Peter would you care to share the brackets that will lift the z motors? Thanks! Would that affect the z axis being able to lower all the way?
Postato : 14/02/2017 10:01 pm
3DPrinTek
(@3dprintek)
About the 300mm lead screw motor:
If you raise em up - what is a doable way cause they have some Z travel which they never use at the bottom - why just simply drill new holes 25mm up from the original mounting holes ?
That way you can use the original mounting brackets and can still use the 300mm lead screw steppers.
And btw. I´ve seen some with 324mm lead screw too - those should be a drop in replacement:
https://de.aliexpress.com/item/Free-shipping-nema17-Screw-stepper-motor-17HS4401S-M8x8-310MM-with-Copper-nut-lead-8mm-for-3D/32550341746.html
rgds, richard
Postato : 14/05/2017 11:39 am
TigerClaw35
(@tigerclaw35)
The question is if it is a good idea to buy steppers eotj 1.5 A and more because the Rambo ensy for example needs 5A for all motors
Postato : 14/01/2019 6:28 am
Steve
(@steve-3)
The stepper motors are probably one of the last things that would fail on a 3D printer unless the wires are physically damaged. I have some much larger steppers on a CNC router that have been running for years and have never had a failure. They are typically designed with a safe operating temperature up to around 100C. The ones in a 3D printer are running WAY below the limit.
Steve
Postato : 14/01/2019 8:39 pm
Pagina 2 / 2
