Re: Problem with first big print
Besides of the usual suspects which you can search easily though the forum (z adjustment, extrusion multiplier, first layer calibration, bed cleaning with IPA/acetone/windex, etc), check the bed screws to see if they are properly adjusted. In my case 2 of them came completely loose and started with warping, adhesion problems and other tragedies after a couple of months of use.
Opublikowany : 07/12/2017 6:13 pm
It does not look like you do not have a good first layer adhesion, and your first layer is not properly squashed.
Try the Live Z adjust method found here:
Opublikowany : 08/12/2017 2:35 am
