Problem with first big print
drew.s
(@drew-s)
I have printed two smaller items without problem from my kit mk2s.
I tried my first large print today and it failed by snagging the corner.
What might need adjusted?
Posted : 07/12/2017 5:50 pm
Jose Ramon Diaz Ramos
(@jose-ramon-diaz-ramos)
Re: Problem with first big print
Besides of the usual suspects which you can search easily though the forum (z adjustment, extrusion multiplier, first layer calibration, bed cleaning with IPA/acetone/windex, etc), check the bed screws to see if they are properly adjusted. In my case 2 of them came completely loose and started with warping, adhesion problems and other tragedies after a couple of months of use.
Posted : 07/12/2017 6:13 pm
AJS
 AJS
(@ajs)
It does not look like you do not have a good first layer adhesion, and your first layer is not properly squashed.
Try the Live Z adjust method found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Posted : 08/12/2017 2:35 am
