[Chiuso] Improving printing of overhang perimeters
jyviko
(@jyviko)
I am printing a part that has a 50degree overhang that runs throughout the whole perimeter of the part. I am not able to get to an acceptable result with (picture 1) or without support (picture 2). I am using Inland PLA filament with 205 / 60 degrees and stock printing settings 0.2mm SPEED.
Any recommendations are appreciated.
Picture 1: With support Picture 1: With supportPicture 2: Without support Picture 2: Without support
Questa discussione è stata modificata 6 years fa da jyviko
Don't buy it if you can make it
Postato : 29/06/2020 11:25 am
RE: Improving printing of overhang perimeters
Good Morning Iraklis,
Have you tried the 0.2mm quality option, or a lower layer height?
Postato : 29/06/2020 11:37 am
jyviko
(@jyviko)
@joantabb
I have not since I was satisfied with the overall quality but I can try with 0.15 mm quality if you think that this issue will be resolved. How about extrusion temperature?
Postato : 29/06/2020 11:47 am
have you done a temperature tower?
the lowest satisfactory temperature will be helpful,  as it will allow less time for drooping...
Postato : 29/06/2020 12:03 pm
jyviko
(@jyviko)
@joantabb
As a matter of fact, I did a temp tower and the best temperature was ~200d. Lower temps looked good as well but the 200d was free of artifacts. I could go as low as 190 without stringing.
I am printing now at 0.15mm layer thickness without support and I am noticing that the outmost perimeter of one of the corners is curling upwards. I guess this is the beginning of the problem. Any ideas?
Questo post è stato modificato 6 years fa da jyviko
Postato : 29/06/2020 3:04 pm
Maybe printing too fast?
Joan
Postato : 29/06/2020 11:09 pm
