Help with bed leveling
nkuck
(@nkuck)
I have been wrestling with trying to get auto leveling set up on my Prusa i3.
Melzi board
Marlin FW - trying to load it
No matter how I configure the FW, I am convinced that the files never get uploaded, eventhough the Arduino IDE confirms "done". I never get a flashing led on the Melzi board during the upload process. I have even tried to do a simple machine name change from the configuration.h file. No success.
The printer still works; apparently from the original Repetier 0.91 FW installed. When I give a G28 command, everything homes. Most other commands also work. When I send G29, I get an "ok" reply but no movement and no errors.
Lost and looking for any help. Thanks.
Respondido : 07/06/2016 3:38 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Help with bed leveling
Hi Noel
This forum is specifically to the "original" Prusa i3 and not clones, so I really don't think anyone here will be able to assist you.
You do need to look on your printer manufacturer's support forums.
Having said that, I also have a Chinese clone with a cloned Melzi board and I have never attempted to upload any firmware to that board, mainly because if it failed, I would have a dead printer and no-one to assist and there is no proper documentation available.
Peter
Respondido : 07/06/2016 6:54 am
