Help for slicer
massimo giandomenico.b
(@massimo-giandomenico-b)
Help for slicer
He people,
i'm designing a gasket for a vintage car but seems that slic2cr does not accept something. The object is manifold, all seems to be ok but there are differences between the object and the preview.
Could someone help me in understanding where is the problem ? and of course how to solve it ?
Thanks a lot
Massimo
PS: How can i upload the file ?
Publié : 12/02/2018 5:59 pm
Re: Help for slicer
Hi. Have you designed this in mm
Using inches can cause problems.
Regards joan
Publié : 12/02/2018 6:33 pm
Re: Help for slicer
Yes i designed it with rhino but i'm using millimeters not inches .
Publié : 13/02/2018 10:28 am
kevin.r5
(@kevin-r5)
Re: Help for slicer
Difficult to say without seeing the file you're trying to slice.
Below the window where you type your post, click the tab labeled "Attachments" then the button labeled "Add files". I'm not sure what the limit on file size is.
I've sliced lots of files made with Rhino without any problems.
-Kevin
Publié : 14/02/2018 1:25 am
Re: Help for slicer
Here is the file, thanks for helping me
Massimo
Publié : 14/02/2018 5:25 pm
Re: Help for slicer
Hi Massimo... is there supposed to be a hole in the middle?
if not, the middle may be too thin
can you zip the STL and post it here please?
Publié : 14/02/2018 5:39 pm
Re: Help for slicer
He,
solved, i redesigned all. Seems that rhino does not accept solids merged at the some level. i set the base (the center of the object, 0.5 mm small than the border and it works
Thanks to all for supporting me 🙂
Ciao
Publié : 14/02/2018 7:26 pm
Re: Help for slicer
thanks for letting us know,
Publié : 14/02/2018 8:46 pm
