defects on outer wall
The3Dfox
(@the3dfox)
How kan I solve this imperfections? I did some research and know that they are named blobs or zits, I am using Cura 2.6.2 for my g codes.
(I am new to this forum and to 3d printing)
Postato : 22/08/2017 2:06 pm
GunnerP
(@gunnerp)
Re: defects on outer wall
This looks like it might be caused by where the printer starts and stops the perimeters. Try turning on z seam alignment or try the Prusa Slic3r. Personally I think the default settings for the Prusa are better in the Prusa Slic3r compared to Cura, but thats just my opinion.
Postato : 22/08/2017 5:43 pm
The3Dfox
(@the3dfox)
The 'Z seam alignment' makes an ugly line in my print. I know that this is caused where the printer starts and stops the perimeter. I will try Prusa Slic3r.
Postato : 26/08/2017 12:32 pm
The3Dfox
(@the3dfox)
On the left is a printed part form cura and the middle and right one are from Prusa Slic3r.
- The middle printed part with 2 perimeters and internal perimeters first
- The right printed part wih 3 perimeters and external perimeters first, also on this printed part you can see blobs on the bottom part.
Are there more options in Prus Slic3r that affect that 'z beam' ?
what options are helping for the blops on the bottom part ?
Postato : 26/08/2017 1:56 pm
AJS
 AJS
(@ajs)
Yes.
Print Settings -> Layers and perimeters -> Advanced -> Seam position
Options are: Random, Nearest, Aligned, Rear
Postato : 26/08/2017 4:24 pm
