Re: defects on outer wall
This looks like it might be caused by where the printer starts and stops the perimeters. Try turning on z seam alignment or try the Prusa Slic3r. Personally I think the default settings for the Prusa are better in the Prusa Slic3r compared to Cura, but thats just my opinion.
On the left is a printed part form cura and the middle and right one are from Prusa Slic3r.
- The middle printed part with 2 perimeters and internal perimeters first
- The right printed part wih 3 perimeters and external perimeters first, also on this printed part you can see blobs on the bottom part.
Are there more options in Prus Slic3r that affect that 'z beam' ?
what options are helping for the blops on the bottom part ?
Yes.
Print Settings -> Layers and perimeters -> Advanced -> Seam position
Options are: Random, Nearest, Aligned, Rear
