XYZ calibration fails on second round
I'm trying to calibrate my newly assembled MK3. Self test passes, but when I run the XYZ calibration, it fails. On the first round of calibration (the one where you protect the bed with a sheet of paper) all four calibration points are found, but on the second round, it fails on point three of four, giving me an error: bed calibration point not found - even though it was found on the first round. I've got an email into support, but I thought I'd ask here to see if anyone has run into something similar. I am using the latest firmware. Any help is appreciated.
Re: XYZ calibration fails on second round
I just got my kit put together and am having the exact same problem: makes it through the first go round, but after the first point on iteration two, it fails with "calibration point not found." What resolved it for you?
Check if your pinda probe is to high. Refer to the building instructions.
Gert
