Scorching Hot Extruder Motor
Checked my extruder motor after a print and it was insanely hot. I checked the other motors and they were cool to the touch. Any ideas? Was printing fine, double checked my build.
Re: Scorching Hot Extruder Motor
I searched before posting the same thing but didn't find this post, just found now so can say I see the same thing. Perhaps the mod can remove my thread since it's a dup of this one now. https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/extruder-stepper-very-hot-t11947.html .
How much is "verry hot"?
60°C? More?
Most NEMA17 steppers are rated up to 80 C for allowable operating temps. AKA - blister you if you touch it long enough hot.
Mine definately feels hotter than my buildplate at 60 degrees. Havent found time to measure yet. Just unpacked and started printing.
The extruder stepper motor will always be much hotter than the other steppers. I haven't measured it, but I'd estimate mine is sitting around 60ºC at a fairly low print speed. I wouldn't be too worried.
Care to explain why?
around 60-70° C is absolutely okay for the extruder stepper motor. No need to worry.
Thanks for the feedback
Printing for 3:19 hours....
Ambient temperature is 21,7ºC...
The extruder motor is sitting at 47.2ºC.
I was going to start a new thread, glad i searched first. The other steppers, xyz are cool to the touch, all less than 80 F.
the E stepper is at least 125 degrees.
125F is like 51C...or there about.
I added a heatsink I had lying around. It gets warm.
[quote=jltx post_id=56149 time=1514078421 user_id=17771]
[/quote]
Those extra zip ties are handy...think I'll do likewise.
I'm running my MK2S and new MK3 (Merry Christmas to me!) right next to each other and have been printing for an hour now:
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
Definitely a marked difference but, if within specs and mods are happy, then I'm okay running it warmer than the MK2S.
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
Note that all the other motors on the MK3 run much cooler than the MK2. Only the extruder runs hotter.
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
MK3 vs MK2S:
X axis: 31.6C / 31.6C
Y axis: 33.9C / 31.8C
Z axis: 29.5C / 36.9C
E axis: 48.8C / 32.1C
Not seeing a huge difference here, other than the MK3 printing a little faster (way faster on solid layers).
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
MK3 vs MK2S:
Your Y on MK2S runs way cooler than mine ever did. It was the hottest, but all were hotter than you get. Yet it printed like a champ.
I suppose you could splice heavier gauge leads on the stepper but I think it's within spec, as is.
