Scorching Hot Extruder Motor
Alex
 Alex
(@alex-24)
Checked my extruder motor after a print and it was insanely hot. I checked the other motors and they were cool to the touch. Any ideas? Was printing fine, double checked my build.
Veröffentlicht : 14/12/2017 6:34 am
Paul Arden
(@paul-arden)
Re: Scorching Hot Extruder Motor
I searched before posting the same thing but didn't find this post, just found now so can say I see the same thing. Perhaps the mod can remove my thread since it's a dup of this one now. https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/extruder-stepper-very-hot-t11947.html .
Veröffentlicht : 14/12/2017 11:52 am
Mike
 Mike
(@mike-8)
How much is "verry hot"?
60°C? More?
Veröffentlicht : 15/12/2017 11:25 am
keith.m10
(@keith-m10)
Most NEMA17 steppers are rated up to 80 C for allowable operating temps. AKA - blister you if you touch it long enough hot.
Veröffentlicht : 15/12/2017 8:28 pm
patrik.s4
(@patrik-s4)
Mine definately feels hotter than my buildplate at 60 degrees. Havent found time to measure yet. Just unpacked and started printing.
Veröffentlicht : 15/12/2017 9:34 pm
kelchm
(@kelchm)
The extruder stepper motor will always be much hotter than the other steppers. I haven't measured it, but I'd estimate mine is sitting around 60ºC at a fairly low print speed. I wouldn't be too worried.
Veröffentlicht : 16/12/2017 2:15 am
john.n13
(@john-n13)
Care to explain why?
Veröffentlicht : 16/12/2017 2:44 am
Paul Arden
(@paul-arden)
Measured mine today during a print, about 58 degrees, so within operating ranges for mine at least. I will admit I haven't check the temp of it on my MK2S since I enabled linear advance there but will do next time I print.
Veröffentlicht : 16/12/2017 6:34 am
Mike
 Mike
(@mike-8)
around 60-70° C is absolutely okay for the extruder stepper motor. No need to worry.
Thanks for the feedback
Veröffentlicht : 19/12/2017 1:34 pm
Impruve
(@impruve)
Printing for 3:19 hours....
Ambient temperature is 21,7ºC...
The extruder motor is sitting at 47.2ºC.
Veröffentlicht : 19/12/2017 5:13 pm
Chris
(@chris-16)
I was going to start a new thread, glad i searched first. The other steppers, xyz are cool to the touch, all less than 80 F.
the E stepper is at least 125 degrees.
Veröffentlicht : 24/12/2017 12:57 am
mmmmmmmmmmmmm
(@mmmmmmmmmmmmm)
125F is like 51C...or there about.
Veröffentlicht : 24/12/2017 1:46 am
JLTX
 JLTX
(@jltx)
I added a heatsink I had lying around. It gets warm.
Veröffentlicht : 24/12/2017 2:20 am
mmmmmmmmmmmmm
(@mmmmmmmmmmmmm)
[quote=jltx post_id=56149 time=1514078421 user_id=17771]
[/quote]
Those extra zip ties are handy...think I'll do likewise.
Veröffentlicht : 24/12/2017 2:27 am
Dracx
(@dracx)
I'm running my MK2S and new MK3 (Merry Christmas to me!) right next to each other and have been printing for an hour now:
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
Definitely a marked difference but, if within specs and mods are happy, then I'm okay running it warmer than the MK2S.
Veröffentlicht : 25/12/2017 9:40 pm
JLTX
 JLTX
(@jltx)
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
Note that all the other motors on the MK3 run much cooler than the MK2. Only the extruder runs hotter.
Veröffentlicht : 25/12/2017 10:46 pm
Dracx
(@dracx)
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
MK3 vs MK2S:
X axis: 31.6C / 31.6C
Y axis: 33.9C / 31.8C
Z axis: 29.5C / 36.9C
E axis: 48.8C / 32.1C
Not seeing a huge difference here, other than the MK3 printing a little faster (way faster on solid layers).
Veröffentlicht : 25/12/2017 10:59 pm
JLTX
 JLTX
(@jltx)
Ambient - 23C
MK2S Extruder - 32C
MK3 Extruder - 51C
MK2-S: v3.0.11
MK3: v3.1.1
MK3 vs MK2S:
Your Y on MK2S runs way cooler than mine ever did. It was the hottest, but all were hotter than you get. Yet it printed like a champ.
Veröffentlicht : 26/12/2017 5:50 am
mmmmmmmmmmmmm
(@mmmmmmmmmmmmm)
I suppose you could splice heavier gauge leads on the stepper but I think it's within spec, as is.
Veröffentlicht : 26/12/2017 5:51 am
