Nyloc seized up
Kwaad2
(@kwaad2)
Nyloc seized up
I broke my Y axis tensioner part, becuase I couldn't get the nut to in, so as per the instructions, I put a bolt through it to pull it in. Except I had an issue. The Nyloc locked onto the bolt so hard it was not funny (and started spinning in the hole). I attempted about 10 things to extract the bolt/nut without totally breaking the part.
Eventually I just took a pair of pliers to rip the bolt/nut out of the plastic. This destroyed the part... BUT I got the bolt-nut out of it!
I then proceeded to spend 10 minutes trying to get the nut off the bolt.
I finally gave up when I broke the nyloc loose, turned about 5 turns, and hit the threads I had damaged trying to remove the said nut.
Has anyone ever experienced a Nyloc Seizing up like this? (I printed a replacement tensioner and it only caused about a 3 hour delay, not a big deal, as it's not a highly visible part. (used E-Sun PLA+ Orange)
The thing is I used to work in Maintance, and I've never seen a Nyloc lock up like that.When you need to use a 10$ extra long Ellen wrench (the japanese guys where i used to work, ALWAYS wrote it as ellen, bad inside joke) and a vice grip, AND a pair of pliers, to "release" the nyloc.
I'm a little upset I need to replace the part, but I already plan on ordering 2 rolls of Prusa Orange, and 1 roll of Prusa Black PETG, for spare parts, so I'm not really worried.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Posted : 26/02/2018 10:10 pm
MattyVee
(@mattyvee)
Re: Nyloc seized up
Stainless on stainless does tend to have the ability of galling from time to time unfortunately. Just the nature of the beast.
Posted : 26/02/2018 11:51 pm
Bigdogbro1
(@bigdogbro1)
Re: Nyloc seized up
Yep! I had the same problem happen on a screw for the heat bed NEW cable cover and nearly destroyed the cover to get out the screw and nut by cutting the screw head off.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Posted : 27/02/2018 8:27 pm
