Maybe a quality issue with MK3
peter.p3
(@peter-p3)
i think i have quality issue on my MK3. I think it just does not print high quality as MK2 did.
can you please check the pictures and suggest a solution? The silver parts are printed with MK3, the brown gears were printed with my old MK2
thanks for your help.
i have the latest firmware
Veröffentlicht : 27/03/2018 11:32 am
pentrena
(@pentrena)
Re: Maybe a quality issue with MK3
It is a common thing that is happening to many users
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/tired-and-indignant-t14872.html
Veröffentlicht : 27/03/2018 1:21 pm
mfon
 mfon
(@mfon)
your idler pulleys are loose, tighten them so they can spin freely but dont wiggle
Veröffentlicht : 27/03/2018 1:39 pm
peter.p3
(@peter-p3)
thanks for both reply, i will check it shortly.
Veröffentlicht : 27/03/2018 1:57 pm
peter.p3
(@peter-p3)
i did tighten them but still the same result.
Veröffentlicht : 27/03/2018 2:49 pm
peter.p3
(@peter-p3)
i tried to read it, but it is quite long, and i did not came to any solution. maybe you see there one?
pentrena
(@pentrena)
There is no solution today
Veröffentlicht : 27/03/2018 3:08 pm
jonathon.b
(@jonathon-b)
I get the same, to me it seems like under extrusion after retraction/travel moves. getting totally fed up with it now too
Veröffentlicht : 27/03/2018 4:51 pm
peter.p3
(@peter-p3)
Do somebody has a good MK3 or all of them are the same?
Veröffentlicht : 27/03/2018 4:54 pm
jonathon.b
(@jonathon-b)
see pictures also
Veröffentlicht : 27/03/2018 4:55 pm
Nathan
(@nathan-5)
I have also been getting worse quality out of my MK3 compared to my MK2. I was planning on selling the MK2 but since I have been having so many problems with the MK3 ( power supply died, filament sensor died, bad print quality) I have been thinking about doing the opposite.
Veröffentlicht : 27/03/2018 6:14 pm
Ilkka
(@ilkka)
😯 There is something strange going on... So many similarities.
https://imgur.com/a/Forza
I have better adjustment on first layer, but did slicer cause those?
Veröffentlicht : 27/03/2018 8:56 pm
Victor
(@victor-3)
I am using Simplify3D and I have the same problems.
I showed a picture with similar problems on Reddit and someone told me it was related to "Coasting Distance" and "Wipe distance".
It is also related with "Optimized starting points on layers" and "Random starting points".
At first I thought I had problems with vibrations or loose pulleys. But when I started changing the previous settings I mentioned, it started to make sense but I couldn't solve the problem 100%.
When printing a cylindrical (with 0% infill) piece I used "Optimized starting points on layers" and the blobs you see on the side of the print aligned vertically. When using "Random starting points" they got randomized.
The coasting distance affected how long the "defects" showed on the side surfaces. I couldn't get to a conclusion on Wipe Distance though.
I had the "force retraction between layers" turned on during all prints.
Veröffentlicht : 28/03/2018 3:42 am
Sendeva
(@sendeva)
What you have going on is a called a Seam.
In slic3r you can change seam position under Print settings - Layer and perimeters - Seam position
you can chose from Random - Nearest - Aligned - Rear
Veröffentlicht : 28/03/2018 4:11 am
Ilkka
(@ilkka)
So should i use random?
Btw, this slicing was made in Prusa, it is presliced file in SD
Veröffentlicht : 28/03/2018 9:54 pm
peter.p3
(@peter-p3)
could it be the quality of pla is bad? i see all the pictures uses the silver pla. did somebody tried with other filaments?
Veröffentlicht : 29/03/2018 10:21 am
