Magnet insertion during pause... safe for bed calibration?
freshmas
(@freshmas)
A little over a year ago david.b14 wrote on these forums that inserting magnets into your prints may be a bad idea:
https://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/pausing-print-job-to-insert-non-3d-printed-items-t3292.html#p25313
Seeing as the mk3 uses magnets to secure the print surface, I am wondering if this could still be an issue. Can we get an official answer?
Cheers!
Opublikowany : 13/01/2018 8:54 am
Re: Magnet insertion during pause... safe for bed calibration?
official answers are few and far between, at the moment...
magnetising the probe points is a nonsense, you will always have a steel sheet in the way, when printing...
the heater clamp screw and to a lesser degree, the thermistor grub screw, might be more of a problem..., and if you have one, a hardened steel nozzle.
I try to make my magnets tight and deep in their holes, and add a drop of superglue to hold them still as the extruder passes over them... so that the magnets do not try to flip out and stick to the extruder...
regards joan
Opublikowany : 13/01/2018 12:33 pm
