I finished my mk3 build today...had some weird things and one problem
tyko
 tyko
(@tyko)
Because i was pretty busy I finished my mk3 spreaded over 6days.
Today I did the wiring and calibration.
First I did all the calibration and then I did the firmware update.. after the update the z offset I did was not good anymore and I need to redo it.
Is this only happening after a firmmawareupdate or is this firstlayer setup needed after every repowering the printer. (Cannot test it because it's printing atm VERY NICELY 😁)
When I did the first time "first layer setup" I've got very strange symbols at the screen(see attachment ). When I restarted the proces it was ok.. .. then I did the firmware update so hopefully it was a one time issue only .
Now a material /fillament question...
When I was building it one of the parts cracked a bit. It was the y axis motor mount.
I am think I overtied it a bit. But it didn't feel like it. When I tighten it like the other screw it just cracked. Luckely tyhe part is still strong enough but still I want to replace the part.
Is the orange plastic type available on the prusa website?.
Publié : 21/01/2018 7:05 pm
Bavaria3d
(@bavaria3d)
Re: I finished my mk3 build today...had some weird things and one problem
Prusa´s only bright Orange filament on the website is this easy ABS:
https://shop.prusa3d.com/en/filament/134-orange-easyabs-filament-1kg.html
A German filament producer sells PETG that (they claim) is similar to the Prusa colour:
https://www.dasfilament.de/filament-spulen/petg-1-75-mm/259/petg-filament-1-75-mm-leuchtorange?c=21
I´ve used their PLA and it is good quality for a nice price, haven´t tried their PETG yet as I don´t have a working printer atm. Shipping outside the EU might be expensive though, can´t comment on that as I´m German.
If you really want the same colour, Prusa also sells replacement plastic parts:
https://shop.prusa3d.com/en/3d-printer-parts/70-spare-plastic-part.html
Cheers,
Felix
i3 Mk3
Engineering Student
Publié : 22/01/2018 12:31 pm
Neolker
(@neolker)
Membre
It should be this one: https://www.filament-pm.cz/filament-1-75-petg-oranzova-1-kg/p51
Publié : 22/01/2018 12:56 pm
steven.g6
(@steven-g6)
I don't have the manual in front of me now, but I believe after firmware updates it says you will need to recalibrate the Z axis, so that is normal. I also got the alien language showing on mine. Restarted and it cleared up.
Publié : 22/01/2018 3:27 pm
