Fan Only
Is there a command from the screen that will check only the fans?
Napsal : 24/03/2018 2:38 pm
Re: Fan Only
I desired the same thing recently when installing a new fan. If I recall correctly, in the test routine, the fans are the first thing tested. Once they passed I just hit the reset button to avoid going through all the other tests.
Napsal : 24/03/2018 7:18 pm
Topic starter
answered:
Re: Fan Only
Thanks Geroge, I ended up doing that. I guess that brings up the saying "Great minds think......) 😀
Thanks again.
Napsal : 24/03/2018 9:20 pm
