Dimensions needed
Hello, as I (im)patiently wait for my newly ordered Mk3, I have a couple of questions that I hope you guys can help me with.
I've been reading a couple of comments about replacing the smooth idler pulleys with gt2-16 tooth idler pulleys. In preparation for when my printer arrives, I ordered two of them and will use during assembly. Ive also read the instruction manual numerous times and don't really like how the y axis belt is tensioned so I'm working up a new idler pulley tensioner. What I need from you guys is to grab your calipers and measure the thickness of the plate that the idler mounts to (labeled "front plate" in instruction manual). I would also like to know a rough dimension from the top of the front plate to the lowest part of the underside of the y axis carriage.
Thank you.
Re: Dimensions needed
CAD files of the frame parts are officially avaialble on Prusa website
Edit: Ohhh sorry. I think there will be no thickness in files. My mistake.
Do you mean this part?
EDIT
Here is the Front plate.
And ...
If you download the printable parts, you will find DXF-files of the Front plate.
I think that thickness of powder coat is abt. 0.15-0.2 mm.
Are they? I thought only the printed parts would be available there. Another reason why I'm asking people is because I'm sure there is a slight build up of powder coat that I want to take into consideration for my modification.
EDIT
And ...
I must've missed that. Thank you.
One last question. Does anyone have a rough measurement from the top edge of the front plate to the underside of the y axis carriage? I want to make sure the part I'm designing will have the proper clearance. Thank you.
Can this help?
Can this help?
Perfect. That's it. Thank you.
