Dimensions needed
MattyVee
(@mattyvee)
Dimensions needed
Hello, as I (im)patiently wait for my newly ordered Mk3, I have a couple of questions that I hope you guys can help me with.
I've been reading a couple of comments about replacing the smooth idler pulleys with gt2-16 tooth idler pulleys. In preparation for when my printer arrives, I ordered two of them and will use during assembly. Ive also read the instruction manual numerous times and don't really like how the y axis belt is tensioned so I'm working up a new idler pulley tensioner. What I need from you guys is to grab your calipers and measure the thickness of the plate that the idler mounts to (labeled "front plate" in instruction manual). I would also like to know a rough dimension from the top of the front plate to the lowest part of the underside of the y axis carriage.
Thank you.
Publié : 10/01/2018 5:03 pm
gkol
 gkol
(@gkol)
Re: Dimensions needed
CAD files of the frame parts are officially avaialble on Prusa website
Edit: Ohhh sorry. I think there will be no thickness in files. My mistake.
Publié : 10/01/2018 5:28 pm
RH_Dreambox
(@rh_dreambox)
Do you mean this part?
EDIT
Here is the Front plate.
And ...
If you download the printable parts, you will find DXF-files of the Front plate.
I think that thickness of powder coat is abt. 0.15-0.2 mm.
Publié : 10/01/2018 5:30 pm
MattyVee
(@mattyvee)
Are they? I thought only the printed parts would be available there. Another reason why I'm asking people is because I'm sure there is a slight build up of powder coat that I want to take into consideration for my modification.
Publié : 10/01/2018 5:37 pm
MattyVee
(@mattyvee)
EDIT
And ...
I must've missed that. Thank you.
Publié : 10/01/2018 5:59 pm
MattyVee
(@mattyvee)
One last question. Does anyone have a rough measurement from the top edge of the front plate to the underside of the y axis carriage? I want to make sure the part I'm designing will have the proper clearance. Thank you.
Publié : 10/01/2018 9:35 pm
RH_Dreambox
(@rh_dreambox)
Can this help?
Publié : 11/01/2018 10:44 am
MattyVee
(@mattyvee)
Can this help?
Perfect. That's it. Thank you.
Publié : 11/01/2018 4:29 pm
