Color print doesn't work
Michel Van Caneghem
(@michel-van-caneghem)
I use the firmware b137. The first time I use "color print" it works, but the following times the head is positioned badly and everything fails. Yet when I use "pause print" and I change color it works.
Opublikowany : 20/12/2017 11:57 am
HackMonkey
(@hackmonkey-2)
Re: Color print doesn't work
I tried Color Print for the first time yesterday, my results were hit and miss also. The first 2 attempts were off, but the next 3-4 were fine.
I tried loading the new gcode files into a couple different tools, hoping I could visualize the changes, but didn't have any luck. Would be great if there were some way to double check before starting a print.
Opublikowany : 20/12/2017 7:13 pm
Josef Průša
(@josef-prusa)
Member Admin
Did you use ColorPrint built into the PrusaControl?
Founder and owner / Majitel a zakladatel
Opublikowany : 20/12/2017 8:44 pm
Michel Van Caneghem
Yes
Opublikowany : 21/12/2017 8:10 am
Michel Van Caneghem
actually "Beer Opener Color_Print" works well
Opublikowany : 21/12/2017 11:44 am
