What support should I use for a TSATool (key)?
Hi!
I would like to print this:
Or this:
https://github.com/Xyl2k/TSA-Travel-Sentry-master-keys
Both are basically the same thing... Those pages don't mention anything about recommended settings for support. If you were to print it, what support settings would you use?
Thanks in advance!
Postato : 17/12/2018 7:48 am
Re: What support should I use for a TSATool (key)?
Looking at the pictures/renderings, the answer would appear to be "none". Looks like everything is designed to be printed flat on the print be and won't need any supports.
Postato : 17/12/2018 1:35 pm
