Wavy lines / ripples in top layer
Stránka 1 / 3
xavierx
(@xavierx)
Hi everyone, this is a problem that is driving me mad (example image attached)
I sometimes get wavy lines on the top layer only.
I have checked and watched the print, which can be perfectly fine up until the 1 before top layer, and then the top layer completely screws up. It does not happen every time, even with the same print, and the same filament.
I have 2x mk3s and 2x mk2.5s and they all do it (sometimes)
Everything has latest firmware and I am using PrusaSlicer 2.2.0
I have seen this problem on various different filaments (Prusa Filament PM \ Sunlu PLA \ Solutech PLA etc) so it is not limited to one filament
I have tried various setttings :-
20/40/60mm/sec for top solid infil
10% / 25% /50% / 100% infill (does not do it on 100% infill)
various inflil patterns and top layer patterns
different temperatures
It's driving me crazy
The example attached was 20mm/s 190c / 25% grid / rectilinear top layer with Solutech real black. The first layer looks nice and flat with no warping
What am I missing?
Napsal : 01/04/2020 8:14 pm
1 lidem se líbí
RE: Wavy lines / ripples in top layer
Are there layers of infill below? If so, this looks like borderline "pillowing". Common fixes are:
  • Add top perimeter layers. These may even out the surface as it moves away from the hollow infill spaces below.
  • Reduce temperatures or improve cooling. Heat will cause the filament to ripple.
  • Reduce speeds.
Napsal : 02/04/2020 5:07 am
xavierx
(@xavierx)
In the example image I provided that was 25% infill, 20mm/s 190c.
I have been watching the prints carefully where the problem occurs, and the first 4 top layers, the print looks flat, it's when it does the slower final top layer that the wrinkling starts to happen.
It also seems to be much more likely to happen on rectangles with round corners (as per the example) than it is on square cornered rectangles
Many thanks
Napsal : 04/06/2020 3:23 pm
DarcShadow
(@darcshadow)
I had a problem similar where in addition to "seeing" the infilll pattern I also had some holes. Increasing the number of top layers helped but I had to increase it pretty high to get a good finish. I ended up creating a step infill near the top. So say 10% infill for most of the object then a few mm away from the top I went to 25% for a few layers, then 50% for a few layers and finally 80% before the top layers started.
Napsal : 04/06/2020 3:52 pm
umuk
 umuk
(@umuk)
I have exactly the same issue as described by Xavierx - have you found a cure for the issue ?
Napsal : 05/12/2020 8:28 pm
Peter M
(@peter-m)
Looks like warping, only a little warping will push the material higher and get this problem.
Napsal : 06/12/2020 9:38 am
umuk
 umuk
(@umuk)
@peter-m-3
Hmm, as also described by the first posting all layers up to the final layer are perfectly flat and smooth.
It is strictly the very last top layer that screws up the surface. And I have doubt that warping just occurs in the last few minutes of this multi hour print ?
Napsal : 06/12/2020 9:47 am
DustlessOrphan
(@dustlessorphan)
Unfortunately I am having the same problem and have tried similar steps to resolve it. Did the OP find a solution?
Napsal : 24/03/2021 10:48 am
mmihi
(@mmihi)
 I'm having the same problem on a large print and only at one corner. Please note that the dark lines are just shadows and not the issue at hand. Has anyone found a fix? Thanks
This post was modified před 5 years 2 times by mmihi
Napsal : 10/04/2021 12:32 pm
Your Z could also be too negative.
Napsal : 10/04/2021 12:56 pm
mmihi
(@mmihi)
@cwbullet
Thanks Chuck. You may be right. It was at some -500. The print eventually came out right though
Napsal : 11/04/2021 8:57 am
1 lidem se líbí
If I see wavy lines, I pack off -0.020 until they go away.
Napsal : 11/04/2021 9:52 pm
jimmyD30
(@jimmyd30)
Posted by: @mmihi
Same here, always (when it happens) on the corner that prints last, I’m wondering if the nozzle temp is too high or not enough cooling. I’m going to lower nozzle temp 10 degrees and see what happens.
This post was modified před 5 years by jimmyD30
Napsal : 30/04/2021 12:30 pm
jimmyD30
(@jimmyd30)
Posted by: @xavierx
What am I missing?
Same happening here, did you find a resolution?
Napsal : 30/04/2021 12:39 pm
Are you guy's using 7x7 Mesh bed levelling? if not turn it on with the LCD Option.
are you using the Prusa First layer calibration tool. if you are, consider using the "Life Adjust 'Z' My Way" process
there are zip files at the bottom of the first post, which may help you
Napsal : 30/04/2021 2:16 pm
1 lidem se líbí
jimmyD30
(@jimmyd30)
@joantabb
Thank you! I did all of your suggestions, ends up heatbed is warped (18,000 hrs). I’ll try my own mod design for mechanically leveling the bed and go from there 🙂
Napsal : 30/04/2021 7:38 pm
Bennco
(@bennco)
Posted by: @cwbullet
Hi - Can you tell me where to make this setting - I'm new to all of this and I'm not sure what you meant earlier by "Z" could be too negative. Thanks!
Napsal : 30/07/2021 2:07 am
ssill2
(@ssill2)
title
@Bennco
he means during the print going to live z adjustment from menu and making the number less negative by .020 so that the nozzle is slightly further from the bed.
Napsal : 31/07/2021 1:10 pm
1 lidem se líbí
Bennco
(@bennco)
RE: @ssill2
OK - Thanks - If I do a live 'Z' adjustment - and lets say that works( I hope so! HA!) - than how do I translate (or save) that into something is permanently adjusted?
Napsal : 31/07/2021 2:05 pm
the mysteries of Live Z
Live Z settings are automatically saved on the printer.
Some folk find they have to reset live Z when changing from PLA to another filament type.
Some folk find they don't have to change Live Z.
I have a Mk2 printer with MMU1 and Pinda version 1, and I have to re adjust Live Z,  on that printer,  early Pinda's were more temperature sensitive!
I also have a number of MK3S and I generally don't have to adjust Live Z on them between PLA, PTG and TPU, I don't print anything more exotic!
Napsal : 31/07/2021 4:29 pm
Stránka 1 / 3
