Vase mode printing 2 perimeters
Dimensions of Three
(@dimensions-of-three)
So I finally decided to try and print a vase using vase mode: https://www.thingiverse.com/thing:42570 is the model in question.
I am using an Original Prusa i3 MK3S with firmware 3.8.0 and PrusaSlicer 2.1.0. The print settings used are the standard ones for Prusament PLA, which I am using the Lipstick Red version of, and a layer height of 0.3mm with the default nozzle, for whatever reason the "spiral vase" mode doesn't print a spiral, it just prints 2 perimeters per layer and leaves an ugly seam at the topleft of the heart.
What am I doing wrong here?
Edit: To clarify, I turned on vase mode and accepted the proposed changes to the settings (so it does have 1 perimeter set up and all the other changes that PrusaSlicer suggested)
Best Answer by Dimensions of Three:
Oh my god... I might be an idiot...
So the zip with the model in it has 2 STL files... a hollowed out one and a fully filled up one... Smart me thought he just needed to print the hollowed out one... little did I know that you print the "solid" one for spiral mode to work... Lesson learned 🙂
Este debate ha sido modificado el hace 7 years 2 veces por Dimensions of Three
Respondido : 15/10/2019 3:04 pm
Sembazuru
(@sembazuru)
RE: Vase mode printing 2 perimeters
I have to ask (because it is something I might do...), are you absolutely sure you are using the right gcode, and not a previously generated gcode that doesn't use vase mode?
See my (limited) designs on:
Respondido : 15/10/2019 3:50 pm
Dimensions of Three
@sembazuru
Yep, never tried anything else but vase mode with this STL... But you can see it in the slicer as well, so it is a Slicer issue... I guess...
Respondido : 15/10/2019 4:09 pm
Dimensions of Three
Respondido : 15/10/2019 4:16 pm
DarcShadow
(@darcshadow)
Are you using the solid model or the hollow one? Vase mode only works on solid models.
Respondido : 15/10/2019 4:18 pm
1 les gusta
Dimensions of Three
@darcshadow
So yeah... As my previous post said: I'm an idiot... I didn't understand the way vase mode worked 🙂 I was printing the hollow one... now that I'm printing the solid one everything works as intended.
Respondido : 15/10/2019 5:27 pm
