There are objects with no extrusion on first layer
Wurzelseppi
(@wurzelseppi)
can´t print that, because Prusa Slicer keeps telling me, that there are object with no extrusion on first layer ?
With Cura it´s working alright?
Any hints ?
Thanks and greetings,
Castle_main_Large_v3_with_top+Support
Publié : 26/12/2020 3:49 pm
RE: There are objects with no extrusion on first layer
Posted by: @wurzelseppi
Any hints ?
As so often, it is due to incorrect STL data. Netfab cannot repair the file and consequently the PS has its problems with it. I have tried to repair and slice the STL in S3D:
Try this:  Castle_main_Large_v3_with_top+Support_S3D
Publié : 26/12/2020 4:23 pm
netfab has problems with the filename. Renamed and repaired (netfab) file -> xxx_fixed
Publié : 26/12/2020 4:31 pm
Wurzelseppi
(@wurzelseppi)
@karl-herbert
Worked.. my friend, you´re the man!! ...
Many thanks and greetings!
Publié : 27/12/2020 12:27 pm
