There are objects with no extrusion on first layer
can´t print that, because Prusa Slicer keeps telling me, that there are object with no extrusion on first layer ?
With Cura it´s working alright?
Any hints ?
Thanks and greetings,
RE: There are objects with no extrusion on first layer
Any hints ?
As so often, it is due to incorrect STL data. Netfab cannot repair the file and consequently the PS has its problems with it. I have tried to repair and slice the STL in S3D:
Try this: Castle_main_Large_v3_with_top+Support_S3D
netfab has problems with the filename. Renamed and repaired (netfab) file -> xxx_fixed
@karl-herbert
Worked.. my friend, you´re the man!! ...
Many thanks and greetings!
