Support enforces falling apart.
HarrisRyder
(@harrisryder)
Hi All!
I am printing this spool design. The print fails at the layer in which the support enforces are added. They seem adhere weakly to the model and fall apart. I am not sure what to do as the first and subsequent layers seem to be printing perfectly before arriving to this point.
Would appreciate any advice on the issue!
wbr,
H
Publié : 13/06/2021 4:45 pm
Swiss_Cheese
(@swiss_cheese)
RE: Support enforces falling apart.
can you provide a .3mf project file?
How-to-save-and-upload-a-project-File
The Filament Whisperer
Publié : 14/06/2021 12:19 am
Dan Rogers
(@dan-rogers)
That shape is going to be a mess with supports, IMO.  If it were me, I would redesign it so there are no supports needed - think of it like a temperature tower.  Reduce the angles so the max angle on the spool is 45% and there won't be any need for any messy supports.  It looks like you are printing with a low temp filament (PLA?) and maybe your temps are a tad too high. I also think you have some bed leveling issues (enable 7x7 bed mesh leveling for some improvement)
Publié : 17/06/2021 1:51 am
Swiss_Cheese
(@swiss_cheese)
you could print this in ABS if you had the right settings, Keep trying you need more experience to get this done properly.
don't get discouraged.
Good Luck
Swiss_Cheese
Publié : 17/06/2021 3:17 am
