Supergluing parts printed on Textured Powder-Coated Spring Steel sheet
Hi, I have an MK2s and MK3s with smooth PEI sheets. Most things I print (PLA) I usually slice in half and print in two parts in the orientation that needs less support material. After that I just superglue the flat sides which works great since both surfaces are really smooth and can be pressed tight.
I was wondering if anyone with a textured bed has done this, and if it works just as well or if the texture gets in the way and needs some sanding.
Thanks!
Napsal : 14/07/2020 12:27 am
