Please show us a picture of your nozzle and heater block assembly.
RE: Prusament PLA problems
Is this a newly set up printer or have you recently changed the nozzle?
It looks like plastic is running down from above the heater block.
Check your nozzle is inserted like this:
https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle-mk2-5s-mk3s-mk3s_2069
See especially under the heading 'Final inspection'
I think your heatbreak and nozzle have a gap.
Gap
I had similar problems a while back. It definitely seems that there is a gap in the hotend assembly.
Maintenance Needed
It's older PINDA so not new setup, I'm going with Improper nozzle Install.
The layer shifting could be a symptom of the leaking nozzle, however it could also be a separate issue that needs to be addressed.
This is not the fault of the PLA.
Regards
Swiss_Cheese
The Filament Whisperer
Gap
Yes, the gap was the problem.
Reassembled everything now it is back to normal.
THANK YOU very much!
