Prusament PLA problems
RR
 RR
(@rr)
I am getting the following problems (see images below).
Any idea why these PLA blobs appear?
I have the newest firmware, ran the calibration wizzard, using prusament PLA.
apreciate your help.
RR
Napsal : 01/10/2021 8:05 pm
Please show us a picture of your nozzle and heater block assembly.
Napsal : 01/10/2021 11:33 pm
RR
 RR
(@rr)
images
please find the images below
Napsal : 02/10/2021 10:58 am
RR
 RR
(@rr)
prusament PETG
I tried prusament PETG and got similar problems. any ideas?
images below.
Napsal : 02/10/2021 2:32 pm
RE: Prusament PLA problems
Is this a newly set up printer or have you recently changed the nozzle?
It looks like plastic is running down from above the heater block.
Check your nozzle is inserted like this:
https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle-mk2-5s-mk3s-mk3s_2069
See especially under the heading 'Final inspection'
Napsal : 02/10/2021 3:32 pm
I think your heatbreak and nozzle have a gap.
Napsal : 02/10/2021 3:42 pm
GidFree
(@gidfree)
Gap
I had similar problems a while back. It definitely seems that there is a gap in the hotend assembly.
Napsal : 02/10/2021 6:41 pm
Swiss_Cheese
(@swiss_cheese)
Maintenance Needed
It's older PINDA so not new setup, I'm going with Improper nozzle Install.
The layer shifting could be a symptom of the leaking nozzle, however it could also be a separate issue that needs to be addressed.
This is not the fault of the PLA.
Regards
Swiss_Cheese
The Filament Whisperer
Napsal : 02/10/2021 7:51 pm
RR
 RR
(@rr)
Gap
Yes, the gap was the problem.
Reassembled everything now it is back to normal.
THANK YOU very much!
Napsal : 03/10/2021 6:27 pm
2 lidem se líbí
